Ok so basically I've got a Sapphire HD7850 1GB GDDR5 and it keeps crashing my system. Sometimes it will be completely fine but as soon as i try and run any games, it crashes about 2 minutes in. It only seems to do this in newer games as it will play Halo CE and Total annihilation ok. However, now I cannot even log on the PC as it crashes just after I put in the password.
I don't think the problem is with my system as it works fine with my backup card (HD6670). I have updated all the drivers and tried the ones that came with the disc as well.
I would go into catalyst and default everything. Load the current stable drivers . OH and you said drivers from the disk so your not using the current drivers .
Ok I have put the 7850 back in and used a different cable from the psu rather than a molex to 6 pin pcie. Setings are at standard and the latest drivers are installed. Now about to try some gaems
No it's not having it, tried playing BF2142 and 5 seconds into the game there were various different colour lines all over the screen and then it crashes
Here is the error report from window, not sure if it means anything to anyone
Problem signature: Problem Event Name: BlueScreen OS Version: 6.1.7601.2.1.0.256.48 Locale ID: 2057
Additional information about the problem: BCCode: 124 BCP1: 0000000000000000 BCP2: FFFFFA80075F48F8 BCP3: 0000000000000000 BCP4: 0000000000000000 OS Version: 6_1_7601 Service Pack: 1_0 Product: 256_1
Files that help describe the problem: C:\Windows\Minidump\101713-17877-01.dmp C:\Users\Peter Rounce\AppData\Local\Temp\WER-38984-0.sysdata.xml
I have a Sapphire 7850 OC Edition that runs just fine and I haven't had any BSODs. What is the exact model of the card and the rest of your system specs?
