2GB: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102998
What are the demensions of this card? I'm checking the 1GB and it shows it there but for the 2GB it's not there. Is it the same?
I have one of those it's the same size as the 1gb vershon.
There actualy a smaller size card it will fit in the smallest of case's.
$200 seams to much for a hd7850 you can find 7870's for that much.
Dimensions 207(L)x105(W)x35(H) mm Size.
http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=1160&lid=1&pid=1654&leg=0
Thanks for the help man! Ill try to get that :3
