Hi so i am makeing a budget pc for about 500 dollars and i am not sure if i should get this card or should i get a evenmore powerful GPU I have a 720p monitor so is this a good buy or should i buy a 7850 for about 40 bucks more please help me.
Get a 7790 or a 7850. Just a little bit more and it has like, double the fire power of the 7770.
You could fit a hd 7850 in a 500 dollar budget
can you literally not eat? if you can't the 7770 will work fine for 720p. but depending how much you can stretch a 7790 or a 7850 is well worth it
