Samsung Odyssey G9 error
I have a very new G9 and since setting it to HDR mode I get a NOVATEK G95T error and the screen is washed out every time I turn my PC on. I have to turn the monitor off and back on to get it to go away. Has anyone else had this issue and how did you fix it?
Thanks all.
First hit using Google…
There might be some display issues. Check your display settings, there must be something wrong, look for it and do some troubleshooting and then it might right up your game, of your display issue.
Thanks Diizzy. I’ve read through that one several times. My issue isn’t random, it is every time I turn the PC on. Every time. But if I turn HDR setting in the monitor settings off, it stops.
Thanks Mashray. I’ve looked and looked again. I don’t see anything in either the Display or Video Setting properties. If I turn HDR in the monitor settings off, it doesn’t cause this issue. I will keep looking though.
