I am looking at monitors for gaming and I found the samsung s22a460b-1 for $130 at microcenter it has everything I want height adjust swivel that kind of stuff but I cannot find what the input lag is on this monitor its a TN panel so it should not be horrable its got 5ms responce time but most do. Tell me what you think
bump
5MS respons time grey to grey is realy alot for a TN pannel in my opinnion, ive got an older TN panel samsung syncmaster 22inch and it has only 2ms response time..
what about something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236175
I am not sure what the grey to grey is on the monitor I posted PRAD said it was 5ms for like red to green, But its not he response time I am worried about it the input lag as its often much longer then the response time. But thanks for the suggestion
