Sabertooth Z77 & Asus Xonar DS 24
Quite new to the pc gaming world and im starting to pick what components to use. While using pcpartpicker everything was going fine but when i picked the asus xonar ds 24 as my sound card there was a compatibilty issue and that the z77 didnt support enough pci express slots and the only other thing i have in the pci express is a 660ti. I've looked more into both the motherboard and soundcard and as far as i can tell there is no problem. Is there something im missing out on involving the compatibility on the motherboard and the soundcard or could it be just a small bug on the the site?
Might be a bug because the sabertooth has I belive 3 PCI-E slots onboard and there should be no real problem with it.
Alright, thanks for the answer.
