Sabertooth am3+ and amd 8350
alrighty SO for a long time now i have been trying to get a new motherboard and a cpu i had a am3 motherboard it work just fine just wanted a upgrade so went to frys and got just that well i came home and got the new mobo set up and put the cpu in well now i dont know whats going on im a big n00b when it comes to the UEFI bios none the less long story short this build seems to be slower then my am3 build when i try to upgrade the bios i get this error image integrity check error fail i dont know what to do
can you please be a bit more specific?
because i dont realy understand what your question is.
Did you upgrade your motherboard to an Asus sabertooth? or what happened?
And what was your previous board?
of course my mistake i was useing a gigabyte 890gpa-ud3h with a 980 II cpu then i upgraded to the board i am useing now which is the sabertooth am3+ with the amd am3+ 8350 i am running 16 gigs of ram here is the ram i am using but on two of the ram sticks one side of the heat sinks fell off
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233240
the heatsing of the rams felt of?
i guess that isnt realy a big deal.
Did you reinstalled the drivers by the way? or a new clean windows install?
i did a fresh clean of windows and i got all the drivers im thinking of RE doing windows because when i got the drivers org. i ended up getting it for the 1st version of the sabertooth and not the r2.0
https://www.youtube.com/watch?v=0Ij6JxlsPLU
allways download the latest drivers from the Asus website.
I personaly also allways update the bios to the latest versions, however this isnt nessesarly needed.
