Hey fellow L1 peeps. First post here, but will try to keep in line with the rules.
I had a S7150x2 delivered from eBay and put it into my PC (Asus WS Pro X570; I LOVE this board!). I got it working just fine at x8, and with the help of a forked gim branch (Proxmox 6.3 with kernel 5.4), got the basics up and running. However I keep running into problems with the temps. The GPU reaches 100C on both GPU cores and stops working.
To alleviate the issue I tried attaching two Noctua 40x20 fans. This elongated the heating time enough to get the modules built and loaded. By the time I could do anything meaningful, the temps were up there again.
I don’t want to look at liquid cooling since I’m paranoid about issues like permeation, leaks, and pump failures. Fans are just plain reliable in my rat maze of a brain. Since PC towers (in my case a Phanteks Evolv X) don’t push the same amount of air as servers, I can’t find a way to cool my GPU. Does anybody here have any bright ideas on how to cool this GPU without attaching a jet engine into my rig?
Just for context, I used a Y splitter cable from my AIO pump header and had the fans at 5K RPM. I also had my case fans (Corsair LL120) at full speed, but all to no avail. The Noctua fans were zip ties to the grill outside the case to pull air through the case. I had no space to attach to from the rear of the card. I have three front fans and three top fans as intakes. The seventh rear fan is exhaust. Attached a pic for context, not the final install form.
Thanks folks!
