Hello, I currently have an R7 2700X at 4[GHz] on all cores in a Crosshair VII Hero WIFI with a G.Skill Trident Z 32[GB] (4x8[GB]) with a 3200[MHz] XMP profile (timings: 16-18-18-38). However, according to memtest86, when I try to run it with the XMP profile I get errors so I reduced the clock to 2933[MHz] with the same timings. Also, according to memtest86, I can only get between 16[GB/s] and 18[GB/s] of memory bandwidth depending on CPU speed and memory speed.
I would like to improve this, so I have 2 questions:
Is there something similar to Ryzen DRAM Calculator for Linux?
Isn´t the rule “one stick per channel”?
So 2 for AM4, 4 for TR4 and 8 for SP3 (except SP3 is a server and you probably need all the memory you can get).
I think that is what they say. Puts less stress on your memory controller, so one less thing to worry about when overclocking. That’s not to say you can’t. I had 32GB (4x8) at one time on my highly overclocked FX system back a few years ago (had to tweak the timings and feed the RAM some more volts).
The memory controller section has the supported configurations. This is not to say you can’t run them faster, but you are essentially overclocking and at the mercy of the OC Gods. As far as I know there is no DRAM Calculator for Linux, so either dual boot or get ready for some overtime overclocking your RAM. Did you try increasing the RAM voltage a bit?
My RAM is running at 1.35[V] currently, I could try increasing it further but I’m not sure how advisable that is. My main goal is to increase memory bandwidth to something like 25[GB/s] or (dare to dream) 40[GB/s]. Since I’m using ZFS as my main filesystem, ECC would be a plus if the performance impact is not too great.
A lot of people go up to 1.4v on the RAM when overclocking with no apparent adverse effects.
In my case, I had to bump the RAM voltage +0.05V to get it stable at its rated speeds. The modules are not on my board’s QVL and I always had a hard time getting them to spec even with latter BIOS revisions. Granted, my RAM are a pair of 2400MHz Corsair Vengeance (2x16GB), so they don’t need that much juice anyway. They have to have at least 1.25V to remain stable at their rated speeds and timings.
