Random… is ALWAYS a bad ground.
The only cable that could be an issue is the front panel stuff. Since it was made for only a certain mobo
IIRC it wasn’t a cable (like, a header to front panel or anything like that) that was causing shorts with this guy’s machine.
Something to do with dodgy earth on the case somewhere.
Either way, everything else has been replaced, i’d isolate the case from the situation and see if the situation improves.
Plan to soon. Can’t really remove the psu easily, all the cables are semi-intergrated with the case design, so as soon as I get a spare psu I will.
If you haven’t solved the problem yet, you might want to have a look at this thread: https://community.amd.com/thread/225795
