My current mobo is dying. Two ram slots are already not working. Tried everything. So I am looking to build a new computer. My main priority is for it to be a Ryzen-based build.
What I need the most is 6 core/12 thread cpu, m.2 x4 pcie 3 slot and as many PCIE slots as possible. However, I also want it to be better than my old mobo. I want this PC to last 5 years or so.
Current build:
i5-4690k
ASUS Z97-C
DDR3 24GB of RAM
RX480 8GB
500GB NVME and 4 ssd raid0
600 Watt PSU
Should I go 1st gen or 2nd gen for cpu? What brand and model for mobo?
I looked at the options and there were just too many to choose from. What controller do I want to have for the biggest window for future upgrade?(future-proofing) How about the second biggest?
Well what I mean is something that would give me lanes for two PCIE gpus. So really more like x8 + x8 or x16 + x8. And then maybe a few x1. And, of course, lanes for x4 NVME. In my current mobo I lose bunch of sata ports, two x1 slots when I use NVME x2. Would be nice to avoid that in the new one. Threadripper might be a bit outside my price range at the moment. I want to stay under 1000 for cpu + mobo + ram.
Okay, a 2700X and a Gigabyte Gaming 7 with Flare X 2x8GB CL14 Ram should be within that price range. That should be relevant for the next 5 years. I’m not comfortable recommending a 6 core since you did say you wanted a 5 year system. And you may want a Noctua D15 instead of a AIO since that for sure won’t have maintenance issues.
I’d also recommend a 850W Platinum Seasonic PSU in case you decide on a GPU down the line.
Is first gen a lot worse than second gen? I know that the latest gen the better, but I am just thinking in terms of raw performance here rather than some extra features that might be in the new gen? Any controller compatibility issues with that?
Last gen doesn’t have XFR2, a feature which helps greatly in more single threaded workflows, boosting them up to 4.3Ghz while remaining under TDP. I’d say it’s worth the improvement, especially for gaming.
That’s not really possible on the AM4 platform, not if you want everything at once.
The AM4 CPUs (not APUs) have 24 PCIe 3.0 lanes total, 4 of those go to the chipset, 4 are dedicated (usually for the NVMe), and the rest is more or less freely available.
However, a lane split is only possible with the X chipsets, usually the configuration is 16 or 8/8. There are some boards I believe that will do 16, 8/8, or 8/4/4, but I haven’t seen anything that does an x1 slot, at least not as PCIe 3.0.
Pretty much all the boards have PCIe 2.0 x1 slots though.
The only situation I could see him using is 2 GPUs in x8 and x8, and 1 NVME, but he needs 4 SATA ports, which 2 are disabled when an NVME is installed.
X470 is the only option within the budget, and the Gigabyte Gaming 7 uses IR VRMs which can last a really long time vs everything else other than the Crosshair from ASUS. (which is more expensive)
X370 is still totally an option, you don’t really loose anything using one. The Gaming 5 or K7 are way cheaper and have mostly the same features. The VRM is still plenty even for 2000 CPUs.
I usually never need pcie 3.0 speeds on x1. Actually, I might not need it at all since I mostly used it for a second gigabit lan card to do LACP. With wifi on board I can get some sub gigabit speeds on it in addition to LAN. Maybe i’ll just use them at the same time with metric priority set to favor LAN.
Hmm it looks like this motherboard(gaming 7 wifi) only has PCIE 2.0 x4 NVME, so that would limit me to 1GB/s and I still don’t know whether I can boot from NVME drive on this board. The solid state has advertised speed of 3GB/S 1.8GB/S read/write.
Sucks that there is no middle ground between threadripper and AM4. I don’t really need 64 lanes and 20(24) is too few. Maybe the prices will come down when the new threadripper 2 releases.
I already saw some places sell TR1 at discounted price, so maybe that’s as low as it will go.
I haven’t seen a board yet that doesn’t (because it would be stupid). Like 99% of the M.2 SSDs on the market are 2280.
Also says so on the website:
1 x M.2 connector (Socket 3, M key, type 2242/2260/2280/22110 SATA and PCIe 3.0 x4/x2 SSD support) (M2A_SOCKET)
Ryzen won’t be noticeably faster than a haswell, particularly an overclocked one, unless you’re doing heavily threaded work. I would suggest buying a new motherboard and sticking your old hardware in it. Tons of the exact same mobo on eBay for around $100, just slot it right in. If you play games, spend all the money you saved on a GTX 1170 when it comes out in a couple months.
Of course if the money’s burning a hole in your pocket, feel free to disregard. I just hate tossing out perfectly fine hardware.
Yea, I was thinking about that route too. Just not a big fan of buying used hardware, maybe if I can find an old stock of a similar board. Also, my personal rule when buying hardware is to try to buy something better than what I had.
To be honest with you, I wanted Ryzen for a long time now. Just didn’t really have an excuse to buy one until now. The current build wouldn’t really go to waste.
I was planning to either sell everything I would no longer need(cpu, ram) or use it for my Proxmox setup. Z97-C can do passthrough and I have a couple of PCIE devices I can pass-through to the guest. This board still technically works, just something is wrong with two memory slots. So I only have 16GB of RAM now because of that and a single channel mode.
