Hi,
this is basically an updated thread from almost two years ago where I got an explicitly negative response to me asking about this:
A copy of the core information:
Can you set the HDMI output settings to 3840x2160, 60 Hz (or more), RGB 0-255, 10 bit per channel colors and HDR enabled?
Couldn’t find a trustworthy answer online, data sheets are sadly meaningless here (previous AM4 APUs also had “HDMI 2.1” but in reality you could only use 3840x2160/60 Hz/8 bpc colors, basically the limits from HDMI 2.0b + VRR).
I know that the iGPU isn’t fast enough for gaming, I’m just interested in a 2D output that handles the specs mentioned above without having to use a dGPU.
I just tested this myself and am now feeling stupid for not examining it earlier myself, I can get a full 48 Gbit HDMI 2.1 signal from the iGPU of a 7800X3D on an ASUS ProArt X670E-CREATOR WIFI (BIOS 2007), connected to an LG G3 TV with an active optical 20 m FIBBR HDMI 2.1 cable:
- It functions absolutely stable for hours, but of course haven’t had the actual time for real long-time testing, yet
BUT I’ve encountered 1 issue I can’t explain:
I get a video signal from the moment of POST until the little Windows logo booting sequence.
The moment it switches to the actual Windows desktop environment the signal is lost (It doesn’t matter what resolution has been selected, even something like 1920x1080/60 Hz doesn’t work).
This can be temporarily
fixed by unplugging the HDMI cable and then plugging it back in, you then get the expected Windows login screen. -
It doesn’t matter if it is a cold boot or reboot.
This issue DOES not appear when you send the system to S3 sleep (suspend-to-RAM) and then wake the system up again.
Does anyone have an explanation for that remaining issue? I don’t want to kill my HDMI ports with unnecessary plugging cycles.
Due to the physical distance between the TV and the computer I am currently unfortunately unable to test other 48 Gbit/s-capable HDMI cables.
And can other users of Ryzen 7000 CPUs confirm HDMI 2.1 (now?) actually fully working with their iGPUs (= UHD with 10 bpc colors at at least 60 Hz refresh rate)? ( @wendell )?
Thanks for your input!
