Ryzen 7 1700 Build log!
I have the parts and I've built the machine!
I'm built it along with 2 other systems, one for my brother, one to be my NAS.
I streamed the entire process on twitch and timelapsed it here: https://youtu.be/4yI7jRsIG1k
I also made a better video about the build here: https://youtu.be/P3Pbh3_VUPY
Full specs:
CPU: AMD Ryzen R7 1700
MOBO: Gigabyte GA-AX370-Gaming 5
RAM: 32GB of Crucial Ballistix Sport LT White (2x16GB) at 2666MHz
GPU(s): Palit GTX 1060 Dual 6GB (ugliest component) (Possibly also a Palit GTX 760 4GB Jetstream for renders)
CASE: Phanteks Eclipse P400 Glacier White Tempered Glass
DISKS: 1TB WD Blue HDD, 250GB Crucial SSD, 120GB OCZ Agility 3 SSD, 500GB Hitachi 2.5" HDD, 500GB Seagate 3.5".
PSU: 650W Seasonic Gold
NAS:
CPU: AMD A6-5400B
MOBO: Gigabyte GA-F2A85X-UP4
RAM: 16GB DDR3
GPU: Integrated Radeon HD 7540D
CASE: CoolerMaster Silencio 452
DISKS: 120GB Kingston SSD, 320GB 2.5" 5400RPM HDD, 500GB 2.5" 5400RPM HDD, 250GB 2.5" 5400RPM HDD, 160GB 3.5" 5400RPM HDD
PSU: Chieftec 550W
Bro PC:
CPU: Intel Core i5-3470
MOBO: AsRock Z68M/USB3
RAM: 8GB DDR3
GPU: Zotac GTX 650 Ti 1GB
CASE: Corsair SPEC-M2
DISKS: 320GB 2.5" HDD
PSU: SFC 500W
Something does not line up here.
Apart from that, have you checked the mainboards supported memory list?
Oops! Fixed.
I already built the machine and yeah, I checked the compatibility first.
