I was wondering if in a 5800X would be the fastest of the three in games if all of them had the same clock. The extra 4/8 cores won’t improve the performance much, but the 5800X has all of its cores on one CCX, which should reduce the latency.
Therefore, if one could get a hand on a really good sample and overclock it, it could be really good for gamers.
They are virtually the same processor for gaming
I liked Linus’ opinion on it. If you don’t need 8 cores buy a 5600x if you need 8 cores, then you need 12 cores.
Do you know why? I mean the 5900X is higher clocked than the 5800X. (But the 5950X is also clocked higher w/o that much difference in that chart. That being said, on GN the 5950X is faster than the 5900X as mentioned above).
Also, please keep in mind that this is a theoretical discussion without any purchase recommendations or price/performance ratios. I’m curious about the technology.
Games have terrible code and rarely if ever need more than 8 cores. Now the 5000 series CPUs have 32M of ram on each CPU complex and seem to not hurt performance.
Ideally the 5800X would be best. never needs inter CCX latency but its 100 to 200 MHz slower. Hard to pass up the 5950X breaking 5.0Ghz single core.
So true, BUT halo 3 MCC has insane multithreading. On my Xeons at 1080p i was pushing the game to near 400FPS with all cores hitting 100%. Who would guess Halo 3?
But if you go with the the two-ccx 5900 or 5950, you can have the joy of a crappy infinity fabric, shutdowns at idle, infinite whea errors, immature bios, excessive heat cooking your ram when the cpu is overclocked,etc.
No the latest gen Ryzen chips (5k)seem to kick intels ass even with cross CCX communications. To boot the higher end chip clock 100Mhz higher each level adding to gaming being best on the beast chip with 16 cores .
Granted there is still lag in doing that and windows will never make there kernel smarter. AMD was smart. When windows will not manage CPU’s. Give them more cache
Hell AMD stumped Nvidia with cache on GPU’s Next year there will be Gcache the latest advance
