…but not through DVI and HDMI. This a constant problem, and the latest driver makes it unsuable now. My screen constantly goes in and out of power saving (standby mode). POFS My solution before was to switch the connection on the card between DP 1 and DP 2, but that no longer works with the new driver. It’s just constantly going in and out of power saving mode, I currently relying on my non Freesync monitor that uses DVI.
If the driver made the dp cable unuseable that should tell you that it’s driver related. Unless you messed with undervolting or something similar, that could also be the issue. Try defaults and or rollback to an older driver or a newer beta driver if there is one. Also make sure chipset drivers are installed
i’ve also had problems with my vive after a driver update with my RX480 GTR (exactly the same as your 580).
It used to always work with Displayport but after the driver update i could not get it to work.
Tried everything.
Eventually i bought an active DP-HDMI adapter for the vive and connected my vive via HDMI.
Yup, definitely driver issue. I uninstalled with DDU and unchecked HDMI audio on the fresh install, but that didn’t help. I switched back to an older driver.
