Will work fine, just make sure to connect the 2 converters to sockets that are under the same phase, and behind the same fuse if possible for the best throughput.
I got a similar device that does 600Mbit/s at best.
Throughout the house are 4 of the things, works good enough while introducing less latency than wireless.
The one I have is rated 2.8kW throughput (230V), I got a whole bunch of things on it, no problems to report in the last 3 (or 4?) years.
