Running a computer in the basement
Hi y'all so I've been planning on running my office in a basement and sadly the basement isn't the best shape, but it has humidity is 55% and about 77 degrees. Honestly I'm wondering what y'all think about doing so. as far as I can tell there is no mold beside the fact I've been banging my head against the wall to get the leaking Hvac system in the basement from leaking. I am in a finished part of the basement so its fairly dry.
I got a mini fridge that is old so that is adding to the heat in the room. I have not moved my main computer but I got my nas installed.
I don't think you'll have any issues
Florida swamp is about 2000% humidity 8 months out of the year 100+F its usually about 77 degrees indoors
Florida Florida Florida is only a state away!!!!!!!
I figured as much just wanted to see if any one else has ran stuff in such a environment.
its cool, most motherboards have humidity protection anyway
but i do live in Michigan and it does get pretty humid through out the summer and ive never had a problem.
