RTX >= 3070 blower-style card: Models, NOISE, temps, performance?
I am keeping an eye on RTX 3000 cards, anything 3070 or bigger, on a blower style card. I am potentially buying out of Germany. I am looking for a new card with warranty. My use-case is a workstation for scientific software development with CUDA, among other techniques.
I have four options, as far as I can see. Two each from Asus and Gigabyte, a 3080 and a 3090 each:
  • GIGABYTE GeForce RTX 3080 Turbo 10G (Rev. 2.0) (LHR), 10GB GDDR6X, 2x HDMI, 2x DP (GV-N3080TURBO-10GD 2.0) @ € 1090
  • GIGABYTE GeForce RTX 3090 Turbo 24G, 24GB GDDR6X, 2x HDMI, 2x DP (GV-N3090TURBO-24GD) @ € 3500
  • ASUS Turbo GeForce RTX 3080 V2 (LHR), TURBO-RTX3080-10G-V2, 10GB GDDR6X, HDMI, 3x DP (90YV0GA1-M0NB00) @ € 1190
  • ASUS Turbo GeForce RTX 3090, TURBO-RTX3090-24G, 24GB GDDR6X, HDMI, 3x DP (90YV0FK0-M0NB00) @ € 2460
(Today’s prices, including shipping and VAT of 19%)
Models
Am I missing an existing 3070 option?
Is it true that, thanks to Nvidia, card manufacturers have basically stopped putting out new blower-style cards for the RTX 3000 variants so people who need such a card have to go down the Quadro path (or its successors, the “A cards”)?
Noise
I am aware that blower-style cards are loud, though there appear to be differences. My research kind of suggests that the Asus cards are louder, though I did not find a direct comparison. Any thoughts, experiences, recommendations? I’ll be working about 2 meters away from this card, in the same room.
Temps
My research suggests that at least the ASUS 3080 variant gets really hot on its back side and memory. For the 3090, I have not found any data or reviews. Any idea how the above listed cards compare?
Performance
Looking at the numbers, it appears that the cards in my selection with equivalent chips are more or less on the same level without noticeable difference. Any objection to this assertion?
Future-proofing: Water blocks?
This is a bit of a long shot and beyond my time and budget at the moment, but I am considering to go for liquid cooling sometimes later this or next year perhaps. I know it’s possible to take an existing air-cooled card and fit a water block to it. If there is one that matches the card. Maybe I have looked in the wrong places: Is such an option available for any of the cards listed above? Or is this a stupid idea? My office / workshop tends to get annoyingly hot during the summer months. Ambient temperatures of 30 to 40°C are not rare events, unfortunately.
I haven’t used any of these personally, but based on the pictures of the pcb’s available online the asus cards seem to be using better quality components
Last one I saw being available in a storefront, was a 2080 Super [I want to say PNY]
Outside of that, has been the Quadro cards
Noise does creep up, since it be a singular fan, trying to pushing that much air across the heatsink/out of shroud. The harder its worked, the louder it’ll be - Since you’re talking about 3080(+) chip, it’ll get WORKED. Do try and find images, of the internal heatsink within, to assure its engagement with sub-components
…Any particular reason for blower-style card?
Case ventilation and the ability to add more cards (GPUs) later. My CPU alone has a 200W TDP. Add a GPU or two and things are becoming tight, even in well ventilated cases. I am running the system under full load for longer periods of time (hours or even days), so it needs to be able to handle those conditions. The general recommendation for scenarios like this, workstations, appears to be blower cards.
Interesting. I am not sure if I can see what you’re seeing. Can you elaborate?
if I’m not mistaken the gigabyte 3090 turbo is the gigabyte oc eagle with the electrolytic capacitors switched out for tantalums
https://www.techpowerup.com/review/gigabyte-geforce-rtx-3090-eagle-oc/3.html
and the asus 3090 turbo is the asus strix oc with the overclocking features removed
https://www.youtube.com/watch?v=2EmhV73Giuc
it’s hard to find reviews of workstation cards, but there are tons of reviews of the gaming/overclocking models which are only minimally different
Say no more. GL
Ive got a few blower cards i use/used daily. Titan V/RTX A4000/RTX A6000 and honestly all arent too loud, sure you can hear them but the Axxx cards at least are more of a humming fan sounds Vs a Screamy fan sound, so id assume it would be the same like for the 3070/3080/3090 blower style cards. My temps on my A4000 reach a toasty 93c max after running some long simulations for a few hours on end due to the small fan, but the A6000 holds up pretty nice at reaching 84c after max peak temp from my testing from 3 days of running ML compute.
I went directly with an RTX A5000 card when I’ve built my new wrx80 workstation in Dec/January, because of
  • Blowerstyle
  • only 2 slots,
  • ECC memory
  • less power draw
  • I’ve initially planned to use the vGPU feature, but now I could use a 2nd old GPU out of an old system for the moment. Maybe I use it in the future when I need to use the slot of the 2nd GPU.
  • at that time it wasn’t more expensive than 3080 - 3090 here, and you could actually get an RTX A5000 while some of the very few 3080 - 3090 cards available , did cost more than the price for an RTX A5000, because of higher demand for the Geforce models.
