That’s true. But it seems like if you beef up on your GPU, most likely the more frames you’ll get in games IF you pair it with good enough hardware. That’s just how I have viewed it from my learning experience.
Sure thing, but it’s still basically a GTX1080, which can go way over 60fps in tons of games at 1440p. If you have a 144Hz monitor I would go for the 2070S for sure.
But you’re against the 2080 for some reason? O.o
The reason is the 2070S has the same performance but is $200 cheaper.
Literally the same performance or very mild differences between it & the 2080?
Small differences, read some reviews.
I have already. I just know others do have differing opinions sometimes.
What opinions? This isn’t about whether blueberry or strawberry rhubarb pie is better (strawberry, BTW), these are provable facts.
I meant when it comes to testing different GPUs. Afterall, not everyone uses the same test methods or the same setups. Hence different opinions based on experience.
Certainly, best to read a couple reviews to eliminate the outliers.
Yep. That’s how I normally do it. Thank you to everyone for your advice & constructive criticism which I was OK with.
I think I at least now know what I’ll be aiming for!
