RTW Case Mod Tribute
It's not finished;
-Paint Touchup
-Top Panel needs plexi
-Front Bezel Needs to be redone - Paint stuck and lifted on door
-Leds need to be wired - bare
-On/Reset Switch need to be wired - Broken
-Letter "D" Needs inside hole painted yellow - forgot to cover
-Needs different color fans - Yellow Cathode fans anyone?
Worklog:
Case Colors
Interior
Bare->Red->Black
Exterior -> Blue->White->Yellow
Other stuff:
New Fan Grills
Black Anodized thumb screws
THIS CASE WILL BE GIVEN AWAY ONCE FINISHED OR USED AS A RTW SERVER
Pictures; (Vid will be on youtube soon) (ETA Tommorow?)
[IMG]http://i44.tinypic.com/2cr2f6e.jpg[/IMG]
[IMG]http://i41.tinypic.com/34694iw.jpg[/IMG]
[IMG]http://i42.tinypic.com/30msewo.jpg[/IMG]
[IMG]http://i44.tinypic.com/iw59uq.jpg[/IMG]
[IMG]http://i44.tinypic.com/2hwzndf.jpg[/IMG]
[IMG]http://i41.tinypic.com/5121dy.jpg[/IMG]
[IMG]http://i43.tinypic.com/2s7apox.jpg[/IMG]
[IMG]http://i43.tinypic.com/b52rkp.jpg[/IMG]
[IMG]http://i44.tinypic.com/2pr8plk.jpg[/IMG]
[IMG]http://i42.tinypic.com/23lkwfa.jpg[/IMG]
[IMG]http://i39.tinypic.com/14ilw0k.jpg[/IMG]
Heyyyy, thats awesome :)
The text look a little bad, you should have written it on an a4 paper, then cut it out, so it gets perfect : P
the painting is really good the only thing thats bad is the text and the uchannel is not strait but thats just my ocd
Uchannel came out like that cause that metal is nearly half as thin as normal cases now days, and as for the text, again I wanted it big and chunky and have a little paint around that, I >Wanted< it like that.
Looks good. But PLEASE fix the text. It'll be amazing then...
All right since so many people think it's so bad i'll redo it tommorow
I like it, it's just the writings :P
I really like the color match too, black on yellow looks straight awesome. What LED color will you choose?
Either green or blue, yellow if I can get my hands on some because i'm considering most motherboards will be black/green/red/orange/white so it will also depend on the other hardware going in
niiiice
I think that green LEDs would look pretty cool.
i attempted a flaming earth, but it didn't come out as the stencil had planned
[IMG]http://i42.tinypic.com/10ga7uh.jpg[/IMG]
step away from the spray paint and come out with your hands above your head
Thanks.
needs more cowbell
Looks nice. How much you spend on all your case mods?
idea!
we should have a case modding contest or something. we decide on a cheap base model and everyone mods it to a RtW theme. the submissions are voted on by logan and the winner gets... something.
Xezmer wrote 11 hours ago »
I would pick up some stencils
Put an Antec Quattro psu in there and its complete : P
Awesome paint job
I C U
Photobucket
