So I have an TP-Link Archer c7 with ethernet port connections, however the place I am in currently in has adsl 2 with only phone line connections..... I don't want to buy a new router, and was wondering if there was a way i could make/buy a sppliter/filter that would enable me to connect from mny phone line to ethernet cable?
I have a random patch panel in the garage for a server too... Is it possible
I'm not sure if I really understand what you are saying but the Archer C7 does not have an ADSL2 modem integrated. So either you need a modem or a different router.
You need a modem to go between the phone line and the router. Either buy one or if you have an old modem you can use that, just put it in bridge mode and plug it in to the router's WAN port.
