I guess the title says it all, I’m looking at both of these microphones and i’ve watched a lot of different videos, but i just can’t decide, i was wondering if anyone that knows a bit more about either mic’s could enlighten me.
I plan on using the microphones to record instruments and do some voice over recording.
I like the mute button build into the Yeti, but i really like the look of the Rode and the included pop filter (for a lower price) is really looking like a good deal.
But just give your opinions and anything that you think i should take into mind. Thank you!
This one is also pretty well reviewed
Also you can get a pop filter for $5 so don't let that be a deciding factor
I was thinking about the At2020, and i would. But everywhere i can buy it from, it's almost $100 more expensive, I can get either of the others for >$180 AUD, where as the AT2020 is at least $280 (the cheapest I've seen)
Also i just listened to a lot of different sound tests, and i think i prefer the NT's brighter fuller sound over the Yeti's sound. Just trying to figure out how to connect it to a suspension stand before i buy it
God that thing is ugly, But Once again, i feel like that one sounds even more bass-ier and warmer then the Yeti.
I'm really starting to lean towards the sound of the NT, But thank you for bringing that up. And thank you to both of you for your help
Although now i'm a little confused about how to connect this mic to a stand, I want to get a suspension mic stand such as this one http://www.ebay.com.au/itm/Pro-Mic-Microphone-Suspension-Boom-Arm-Desktop-Stand-Holder-Mount-for-Broadcast-/271894544654?hash=item3f4e2d810e:g:RXcAAOSwpDdU4D25 But i'm not really sure how to connect it. Does anyone know how?
You probably don't want to be limited to USB only, consider getting something that also have a annalog output, like the Yeti pro for example.
