Risk of a Private Network on a Public Network
I’m currently connected to xfinitywifi using a pocket router setup as a private network with a wireguard vpn.
What are the risks associated with sourcing you private network over a public network?
Thanks
Mainly fingerprinting I think which can be mitigated with random mac address
there are several layers aside from wireguard that need to be secured to not allow a bad actor to spoof things.
Is your DNS encrypted as well?
Not sure, what setting should I look for in the router settings?
DNS is now encrypted, MAC address is cloned and so your aware the router is connected through repeater not Ethernet, tethering or cellular.
The three options for MAC Address on router is factory, clone and manual.
Depends, if you’re connecting a router to the LAN and have everything connected there, this is how low cost ISP’s do it all the time.
Just got an email today from a client who outsourced their ISP overseas and last time I was there could plug into any port on the switch and see ALL users across the entire luxury condo network.
Anything outside your LAN router is a hostile network, treat it as so and move on.
you-have
That’s bad LMAO
Yeah since it’s going through a repeater lock the ports down that you’re not using. The mac address randomization would only make sense on the repeater in that case since it’s the only device exposed to the public network access point
How do you lock ports down? Block all new devices from connecting? And just change that setting momentarily if I need to add one of my devices to the network?
you just said alot of things
firewall rules
How aggressively? If you’re tip of the spear then MACSEC, most just use RADIUS servers for enterprise network authentication.
Not how that works, you need to enroll the device through your authentication server.
What you are describing would require decent hardware and plenty of setup time. But you’ll learn a LOT about networking. Just remember your MAC address is MY MAC address
I suggest reading about ports and networking. It sounds like you’re in over your head a bit.
a firewall that only allows your wireguard port would be ideal
also a vLAN separate from the public network for local devices
