I’ve been seeing a lot of of “I need to build a computer for [application that isn’t gaming]” threads that play out as follows:
- OP asks what balance of compnents makes sense for their use case
- The forum recommends gaming build style specs or HEDT parts for no reason other than “Quad cores are old news” or “but you can play minesweeper at 2k+ fps” or similar.
- The forum then shouts down sensible solutions when the more experienced members try to contribute
So I’m compiling a list of “right size” parts lists that perform well for specific use-cases that aren’t gaming, so people here at least have a point of reference. I’ll be updating this as time permits and people suggest updates and discuss them. These builds will not be bargain basement, nor will they be extremely high end.
The goal is to strike a balance where you tick all the “Must Have” boxes, plus a few extras are readily met, but you aren’t paying for hardware you don’t need. I encourage suggestions and discussion below, as this is a living document. If you have level 3 membership status, and want to contribute, You’re welcome to as long as you PM me beforehand so I know what you intend on changing.
2d/Photo Editing/Graphic Design
Must Haves (in order of importance):
- A properly Spec’d, well calibrated monitor (and colorimeter)
- Workflow specific peripherals (drawing tablet etc.)
- performant disk I/O
- decent single threaded performance
- enough GPU Horsepower to drive accelerated functions
Nice-to-Haves:
- 10-bit monitor and GPU with 10 bit color support
- A high end, color accurate printer
- dedicated scratch disk
Not Important:
- gaming performance
- high refresh rates
- massive storage capacity
- core count (past quad)
- overclocking
Reference build:
Part | Model | Rationale |
PSU | Seasonic S12II 520W | cheap, reliable, fits power needs |
Case | Corsair 200R | Inexpensive, nice to build in, professional looking, good compatibility, comes with good fans |
Motherboard | ASRock AB350M | Inexpensive board with good reviews, has every feature you’re likely to need, option for m.2 scratch disk. |
CPU | Ryzen 5 1400 | Powerful enough for photoshop, Krita and Illustrator, half the price of other HT quads that fit the bill |
GPU | FIrepro V7900 or W4100 | Full color bit depth pipeline support, good enough for any 2d program’s acceleration needs, inexpensive with certified drivers. |
RAM | 2x8GB G. Skill Flare X F4-2400C15D-16GFXR | Cheap ram on the supported list for the motherboard. |
Storage | 1x 1TB Crucial MX300 or ADATA Ultimate SU800 SATA 2.5" | SSD performance, covers storage needs in one drive. Cheaper than an m.2 scratch disk + boot disk + hdd combo while leaving the option of a scratch disk open. |
Montior | Dell UP2516D, Asus Pro Art PA249, or Philips 276E6ADSS | Either 10 bit or 99% aRGB 8 bit, best performers in their price class for color reproduction and industry print-accuracy. Don’t get the 10 bit (asus) option if you don’t intend to get a firepro or quadro. |
Colorimeter | Colormunki Display or Pantone Huey Pro | This is absolutely necessary for any graphical work. Even if you don’t get a high end panel, you need one of these to get the best performance out of your panels and match them in your environment. Both of these models are reasonable and DisplayCAL compatible. |
Useful Peripherals/addons:
Pen Tablet | Huion H610 Pro, Ugee M708, Bamboo Fun | Huge boost for illustration work |
Pen Display | Artisul D13, Huion GT-190, Ugee UG-2150, or Yiynova MVP22U(V3) | These perform comparably to Wacom Cintiqs, for the price of an intuos. huge workflow boost with 1:1 feedback over traditional tablets. |
M.2 Scratch disk | Samsung 960 EVO 250 GB | Increases performance somewhat in adobe applications, probably low value for money, but a valid improvement depending on your specific needs. |
Video Editing/3DCG
- Adequate, Reliable Storage space and performance
- decent multithreaded performance
Nice-to-Haves:
10-bit monitor and GPU with 10 bit color support, certified drivers for 3d
Decklink or 3d navigation peripheral
high bandwidth footage ingestion
Not Important:
- overclocking
Reference build:
PSU | SeaSonic SS-750AM2 750W | cheap, reliable, fits power needs |
Motherboard | ASRock X370 GAMING X | Inexpensive board with good reviews, has every feature you’re likely to need, option for m.2 boot disk. |
CPU | Ryzen 7 1700 OR Ryzen 5 1600 | Powerful enough for grading, 3D and rendering, by far the cheapest chip in it’s performance class for this workload. |
GPU | RX 480, 580, GTX 1070 | Cheapest accelerated rendering options, No certified drivers or 10 bit support, but most cost effective outside of color grading specific builds. |
RAM | 4x 8gb G. Skill Flare X F4-2400C15D-16GFXR | Cheap ram on the supported list for the motherboard. |
Storage | 1x 2TB Crucial MX300 or ADATA Ultimate SU800 SATA 2.5" + 250GB Samsung M.2 Boot Disk + (x amount) 8TB Toshiba X300 Cold Storage HDD | Cheaper than using an external NAS to save projects, and you need a dedicated scratch SSD to make large projects workable. |
USB 3.0 or PCIe card reader | depends on your camera’s storage format | must have for fast footage ingestion. |
Suggestions incoming. |
4k HEVC Streaming Client/High End Cord Cutting
SECTION UNDER CONSTRUCTION
- Adequate HEVC Decoding
- Small size
- Surround Sound Support
- UHD Format Playback (BDROM, Youtube and Silverlight)
- Adequate Networking Capability
- Quiet Operation
Nice-to-Haves:
- 10-bit decoding support
- 4k60 Support
- Home Theater control via remote
- Ultra low profile
Not Important:
- Gaming Performance
- Storage capacity
- productivity
- core count (past duo)
- Overclocking
- RAM
Reference build:
PSU | FSP 220W FSP220-60LE | cheap, reliable, fits power needs and form factor |
Case | nMediaPC HTPC 1800B | flat, cabinet friendly form factor, cutout for front for IR sensor |
Motherboard | MSI - B250I GAMING PRO AC | Built in AC wifi, small form factor, 7.1 Surround Audio Support |
CPU | Pentium G4600 | Has full 10-bit 4k HEVC decode support, seems to be better supported than the 4560 at this juncture, and they’re the same price anyway now. |
RAM | Crucial CT8G4DFD8213 | Inexpensive, perfect for this application. |
Storage | ADATA - Premier Pro SP600 64GB | Inexpensive Boot Disk, enough space for All the client software and whatever OS you decide to use. |
Disc Drive | LG - UH12NS40 | Reads blu rays, inexpensive. |
IR Sensor | FLIRC 2 USB | Seems to be the best supported IR remote reciever, wide compatibility, You may want to consider internal front mounting using a usb 2 header to female cable. |
Remote | Logitech Harmony 350 All in One Remote | Good universal remote with App Hotkeys, configurable through FLIRC. |
TBA |
I encourage you to link this thread to new posts asking for a build application mentioned here, and contribute your own applications where your experience applies. Tell them to control + F for their use case.
