RHEL with Samba as domain controller
Hi,
I have 2 RHEL 6.10 virtual machine running Samba version 4.4.16 for our LDAP domain controller, yes both OS and Samba version are old which why I like to ask the community for assistance. I like to update Samba version to the latest supported version so what are the challenges I will encounter and how to update the Samba version properly on a running production environment?
Since our RHEL 6.10 is End-of-Life, is it more approachable to build another current Linux OS, install latest Samba version and join this new system to an existing domain controller role?
There you have it; previous administrator ignore updates and life cycle management and I have an OS and Samba that are out-of-date.
I truly appreciate any leads/assistance.
Thanks.
i run my SAMBA DC on Debian, but you could do a similar upgrade process.
  1. clone the VM and keep the clone turned off
  2. run upgrade on the running system and see what happens
    2a. test things like joining a machine to the domain and changing a password
  3. if the system is hosed, delete it and boot the clone.
  4. build a new system, join it to the domain, demote the old one
    5…
    6.profit?
My brother in christ I feel your pain.
In my experience there is less friction with doing a cut over to a new server. Makes rolling back the changes easier.
Doing an in place upgrade from 6 → 7 → 8 will be… might as well put in your 2 weeks now to save time.
7 goes EoL like this December so you should upgrade to that.
The sort of things you’ll need to look into would be breaking changes between the major version to your config settings. It all should be similar but you need to first build a PoC with the new stack so you get a feel for it. Then you can start to test things. KTLO for the current prod env only. No new changes!
Try and generate an estimate for how long it will take to do a migration during a maintenance window of user data based on psuedo-random sample data.
Coordinate with any relevant stake holders. I.E make sure your Network Admin(s) are aware of anything as well as the end users, and make it straightforward for users to report issues post migration since there will likely be issues.
Have your rollback plan ready to execute should things go belly up.
I wouldn’t upgrade RHEL, Samba as an AD DC is not supported on later RHEL versions.
I think your plan to install a different current Linux distro that supports Samba as DC and join the existing domain is a better option. When the new DC’s are up and running you can remove the old RHEL 6 DC’s from the domain and decomission them.
