I'm building a gaming PC for my friend and I was hoping you guys could critique any part choices. Mostly be playing AAA titles like BF4 and GTA as well as less demanding games like LoL, Smite and CS GO hoping to get 60fps on ~ultra. Keyboard, mouse and monitor is needed as well as the tower. No OS required. Ideal price would be between £800 to £900 but £1000 is the absolute maximum.
looks good to me, maybe you could concider a Xeon E3-1231-V3 over the i5 for your modeling work, cause this chip offers 4 cores 8 threads. and its just a few pounds more then the most expensive i5. But of course the locked i5-4590 is a bit cheaper.
Thanks for the suggestions guys. An SSD upgrade might be a possibility, I'll have to ask if my friend is able to fit it in their budget. Would the i5 perform better than the xeon in gaming scenarios because he'd prioritise that over modelling.
Word of warning, stay away from CCL computers. I have had nothing but issues with them in the past, mainly focusing around very poor communication and lack of updates to the customer.
This will probably give you the best value you can get though there is room to replace some parts with a similar product. The 16GB of RAM is merely for the modeling work and not really a requirement though it is very nice to have extra RAM if you are one that has many tabs open in chrome or one that hosts a minecraft server. Reduce it down to 8GB if you do not require the extra RAM
The price difference is absolutely minimal and should he decide to get an I5/I7 later (Perhaps a used or new 4790k) then he will still be able to use the 1866. Without XMP it will default using JEDEC to 1333 (probably cas 9) anyway so saving 4 pounds on RAM which is most likely slightly lesser in quality is fairly redundant
The Xeon E3-1231-V3 will perform the same in games that using up to 4 threads then the 4590. But in well optimzed multithreaded games, it will edge out the i5.
I put slower ram because of max compatibility not price. I once saw a i7 960 burn out an ASUS Rampage III because it supported 1066 mhz ram and it was on 2133mhz. Intels dont work well with "probably" ;)
