Hey fourm, first time posting but long time watcher of logans videos.
I finally have built my first computer, gaming computer i've been wanting.
Specs
MOBO: Asus Sabertooth z77
CPU: Intel i5 3570k
CPU Cooler: Zalman CNPS9900MAX
RAM: Corsair Vengeance 16Gb (2X8Gb) 1866
GPU: EVGA GTX 670 FTW
PSU: Thermaltake 850 80 plus bronze
HDD: Seagate 2tb 7200rpm
Case: Antec Twelve Hundred
Just wondering how I did for my first ever build considering my only experience is replacing ram.
I am a little worried about the psu considering I never seen it used in a build.
No OS yet, Just wondering if their is something I should change first with the hardware. And everything is already put together and booted it up once. Everything seemed to be working. I would appreciate any feedback
If it starts up you don't have to change enything :). Something manny non experienced pc builders forget to do is to configure the fans etc, manny mobo's are set to full speed on every fan conection so look at the temperatures and lower the fans speed etc. Do this and your computer will run nice and quiet. But you can do that after installing the OS.
The psu should be okej it is 80+ and thermaltake is a fairly known brand and most of the people reviewing it seems happy with it.
The PSU is way overkill, unless you plan on a multiple GPU configuration. A 650W will be fine. If you're not gonna edit( or even just small edits, nothing serious), than a 7970 will serve you better. Also, 16GB is also overkill. Games and applications barely use 4GB, so 8GB will save you some money without any performance loss. I don't know that particular CPU cooler, but maybe swap it out for a CM Hyper 212 Evo? Or if you want to go for an even cooler, uh, cooler, a Noctua NH-D14
Alright, I will browse a few more ssd brands. I built this computer for gaming but it seems I went a little to wild on parts while not knowing what the usual requirements are. O well, better to have it and not need it than need it and not have it.
