Reverse KVM
I would like to be able to switch between multiple screens/keyboards connected to the same machine. Switching displays in windows is annoying and often activates the wrong screen by default.
Is it possible to use the KVMs in reverse, connecting the PC to the output side and the different screens and keyboards to the PC1 PC2 connectors?
Can’t find an edit button, but wanted to clarify.
I want to switch the pc from being connected to the screen and controllers pointed at my sofa to those on my desk.
Well there’s HDMI/DP switches. And Monarch GitHub - Nuzair46/Monarch: Detach, restore, and switch monitor layouts without touching cables. is a thing that lets you software-unplug displays.
And no particular loss to having extra peripherals plugged in, so that’s not really relevant.
So this seems like a dedicated video switcher solution that we do not sell at this time.
Thanks for the hint to the Monarch repo! This should work nicely. Good point on the HDMI switches also. Cheers.
