Reuse an old psu
I am going to help a friend rebuild his pc for fallout 4.He has an alien ware with a 600w psu. If i do a 6600k build would i be safe to use the old psu or should I get a new one.
what are the rest of the system specs?
It will have a 6600k, ASRock Z170 Pro4, 16gb ddr4 ram, 1 ssd, 1 large hdd, and i haven't decided on the gpu. anything from 960 or 380 to 970 or 390 nonx
also 2 optical drives.
How old is the PSU?
I estimate 2008-10. The processor was a e8400, ddr2 ram, and gtx 295. If that gives you a date.
600W should basicly be okay, but what brand and model is it?
Maybe the psu has been changed in the past.
I need to look at the list of parts from the receipt because there was not obvious branding on the psu. If it is some no name brand should I replace it?
Oh, I've re-read your post regarding your GPU plans. Yeah ... I'd buy a new one. I had the impression you would be using the iGPU.
I plugged your numbers into the PSU calculator of Enermax ... and they tell me 577 Watt minimum. These are worst case numbers with a 390. I'd really get a new power supply.
But I'd keep the old PSU. It will be useful for an office system or an HTPC.
well im tempting to say that i would recommend to replace it.
However it still can be a decent unit even without branding on it.
But if there is no branding on it, i assume it could be as old as the setup is.
And in that case, i would personaly recommend to replace it.
It could even be the case that the psu also lacks on certain connectors like dual 8 pin pci-e or 8 + 6 pci-e power connectors for the todays graphics cards.
Ofc there are molex to pci-e adaptors availeble, but i´m personaly not a fan of using adaptors like that.
If the psu lacks on those certain connections, then i would assume that the psu will not be ready for a powerhungry GPU from nowdays.
I would say double check the psu.
But if there is any money for a psu upgrade, then dont hassle but just do it!
Thanks I will look at probably the 970 with a corsair cx600m. Unless you think the 390 would be better.(need to do 1080p for about 7 more years)
i would go with the 390 then.
slightly more "future proof" wenn it comes to vram.
But i hate to use the word future proof, because it basicly isnt realy a thing,
wenn it comes to the tech world.
If its that old and you plan to reuse it get at least a cheap PSU tester to check if voltages stay within the norms after those years.Second thing is capacitor aging,some say its a myth but still I would factor that in.You woulnt like your new system to explode.Also +12 volt rail total wattage, it would be nice to know that before you get overclockable cpu and gpu.And final question , if it has enough connectors (pci-e 6 and 8 pin, 8 pin cpu etc.) so you wont have to use adaptors etc.Get a new one, there is no need to go for 1500w psu but having extra watts there helps a bit, Psu running at 100% is not the best idea also leaves some room for upgrades. Try to save money on different parts but get a solid psu.
Ill do the 390 unless a sale on something else in the range comes up when the build starts.
Yea but you can make it future resistant. Picked z170 and ddr4 so those parts can be reused on a future build if necessary.
Ill probably get a 650 or 600 watt psu. The gpu is actually going to draw less power 390 vs a gtx 295 dual gpu.(really old)
What would you suggest for a psu. I was looking at the cx600m with is 45 with rebate now but I seen where people say there not that good.
That is what i read too, might have been a bad batch, things like that happen.I run multi gpu setups for ages so have experience with entry level psus :( There is a lot of good PSU threads here .
