I’m just making a thread explaining that Davinci Resolve 16 and Blackmagic Capture cards work on Debian 10.
On a side note Ubuntu and Pop OS! don’t seem to be able to super key game windows to other monitors. This is not the case in Debian 10 or Fedora 30.
Grabbing Debian 10 nonfree makes the install easy with firmware for wifi adapters and gpu
/sbin/usermod -aG sudo dp27thelight
sudo shutdown -r now
that makes sudo possible
sudo apt install libnuma-dev
sudo reboot
sudo apt-get wget
wget -qO - http://repo.radeon.com/rocm/apt/debian/rocm.gpg.key | sudo apt-key add -
echo ‘deb [arch=amd64] http://repo.radeon.com/rocm/apt/debian/ xenial main’ | sudo tee /etc/apt/sources.list.d/rocm.list
sudo apt update
sudo apt-get -d install rocm-dev rocm-opencl-dev
sudo apt install rocm-dev rocm-opencl-dev
sudo usermod -a -G video user
echo ‘ADD_EXTRA_GROUPS=1’ | sudo tee -a /etc/adduser.conf
echo ‘EXTRA_GROUPS=video’ | sudo tee -a /etc/adduser.conf
echo ‘SUBSYSTEM==“kfd”, KERNEL==“kfd”, TAG+=“uaccess”, GROUP=“video”’ | sudo tee /etc/udev/rules.d/70-kfd.rules
reboot
/opt/rocm/bin/rocminfo
install davinci, it will crash, but then boot I suggest run in terminal first time
/opt/resolve/bin/./resolve
for capture cards
sudo apt install dkms build-essential linux-headers-$(uname -r)
sudo dpkg -i *.deb
or however you like
Wine runs with LLVM 7 on stable, still have more to learn about debian, I’m curious if testing or unstable would offer better gaming performance
again, I would sudo apt-get -d install rocm-dev rocm-opencl-dev
updates can always break set ups like this, I already did a full offline install so that I can always rebuild this set up.
I got Davinci Resolve 15.3.1 working in Fedora 29 and Fedora 30 past kernel 5.2.17, but I used some proprietary opencl packages and an older addition of opencl I believe.
Maybe nobody cares, but I love this setup so they’re you go
considering all the distros dropping 32 bit, Debian keeps looking more appealing.
Technically this works in Ubuntu and Pop OS!, but those distros feel slower and had decent amount of glitches compared to Debian.
I think I’m about to delete windows 10 off my laptop and dual boot Fedora, Debian and Manjaro.
