I have my PC where I now recently tried to get the Resizable BAR and Graphics accelerated Hardware scheduling to work. Having two problems here. GHS is not showing up under System-Display-Graphics settings. And setting Resizable BAR on auto in Bios does not properly enable it, it should work if the resources tab would show you Large memory range. But I only have medium ones. To enable GHS, I added the 32DWORD to the registry. But I am unsure if it works. I want to get both of them working.
Windows 10 Pro 21H1
R5 5600X
RX5700XT
X570 Aorus Ultra
Bios settings: (enabled)
fTPM
CSM
SVM
4G decoding
Settings: (auto)
Resizable BAR
CPU performance boost
If your Windows is installed in Legacy mode you cannot boot anymore after disabling CSM. I remember it being possible to change your installation type from Legacy to UEFI so some googling might help you there.
Disclaimer: I am not sure whether disabling CSM wiill fix your RBAR issue
I’ll try to change it to UEFI but I think I might be better off going Revi OS at the same time so just getting a backup drive and then wiping my C:\ and installing Revi on it.
