Resident Evil 5 Pc?
Does any one know if there is going to be a resident evil 5 for pc.
I don't know, i think I heard somewhere that RE5 is developed for PC, then ported to their consoles. RE4 came out on PC, so RE5 will probably be on PC. I don't care though, RE isn't scary anymore, it's just like any other action packed game now.
"I don't care though, RE isn't scary anymore, it's just like any other action packed game now."
so true, they have pretty much striped it of what made it great. Its just easy, lacking depth, or tension.
Capcom hasn't said anything, so at this point, no.
im sure it will be on the pc but not for a while
and im guessing it will have none to little AA and zero multi gpu support like all other half assed console ports.
yes, at the same time as the other releases.
http://en.wikipedia.org/wiki/Resident_Evil_5'
Learn how to use google yeah?
cough that would be wiki cough
Its more confusing than that, capcom has officially denied that there is going to be a pc version, or that there are any plans at the moment, then at the same time they sent a list of release dates out with the pc version launching along side the console versions. As far as im aware though capcom has not confirmed that this is correct and not just a mistake and they haven't retracted their previous statement that they dont have plans for a pc version at the time. so some sites have it set to launch with the other versions (ex gamespot) but at the same time there isnt any major American retailer listing a pc version as existing.
idk if anything has changed.
packet wrote 4 hours ago »
How do you think i acquired the wiki link?
I'm about half way through it on the 360, shit sucks. but by shit I mean your partners AI. half the time she's shooting me in the shoulder, the other half she just wastes ammo. they made it depend to much on both characters like Army of Two. other than that it's not bad, some scenes re used from RE4 though.
clownpRon wrote 32 seconds ago »
you torrented that shit?
