Greetings,
Not sure if there’s a specific category this needs placing in, let me know if I need to move/remake this.
Having some issues finding relevant info on this (you’ll see why shortly), so figured I’d get it all written out and hope for some advise.
A family member is having issues with a PC I built them a while back.
It’s a scrap build made mostly of used parts, and has recently developed a boot problem:
- Randomly, on the pressing the power button, nothing happens.
- No lights, sounds, or fan spins. Nothing.
- Every time this occurs, it’s fixed by doing a full power reset (turn off, unplug, hold power for 30 seconds), after which point the system boots up without issue.
The problem doesn’t occur frequently (around every 2-3 months), but it’s difficult to diagnose, especially given the age of the parts. I’ve tried researching in a few places so far, but as you can imagine, “PC doesn’t turn on” is a bit too generic without this wall of text to provide context.
The system shows no other signs of trouble, and everything works fine aside from this minor hiccup every couple months. It was built around a year ago, and these symptoms only started up a few months ago.
Specs (that matter) are as follows:
- CPU: i5-6500 (used, bought off eBay)
- Mobo: MSI B150i Gaming Pro (used, bought off eBay)
- RAM: 8GB generic DDR4 (unknown, can’t find how or where I got it, but believe it was new)
- PSU: Silverstone Strider 500W (used, bought new years ago for a spare build)
- SSD: Crucial MX500 (new, bought off Amazon)
I don’t have many (if any) spare parts available for this rig, and getting extra Skylake gear just to test is not only tricky, but potentially expensive.
I’ve seen some sites and forums suggesting an issue like this could be things the cables, or motherboard, or CMOS battery, but I’m not sure where best to check for an issue that is random, easily fixed, and could be caused by almost anything in the system.
I’ve experienced similar issues with client laptops at work, and also seen the exact same fix get them up and running without trouble. Which leads me to my ultimate question(s):
- Where do you all recommend to start with this? Or is it worth just replacing the entire core set?
- Should I even be worried about this “issue”? Or is it a normal part of operation for some PCs?
Let me know if you need any more details.
Any and all help is appreciated.
Regards,
Lord of Time
