I know I would watch it...then watch it again. I have found tons of written information about air cooling on the internet however I haven't come across a good video that educates and gives a general understanding of the different approaches to air cooling. A video that uses a real build as a demonstration (an R4 for example...) would be way more helpful than the written guides I have read so far. I looked through the older videos and couldn't find this type of educational guide.
I feel a video that explores the 2 stances of positive pressure and negative pressure in detail would be very informative.
Should I go Positive Pressure?
Should I go Negative Pressure?
Do I want a side fan? (and what are the benefits?)
If I have a side fan, how does that affect the rest of the fan configuration?
I don't think this is a bad idea in the slightest, but I do think its a rather straight forward topic that doesn't have many points of discussion...
Positive or negative air pressure? Positive pressure is preferred to reduce the amount of dust which enters your case as many have additional (often unfiltered) perforated openings. Generally neutral to slightly positive pressure is preferred.
Work with convection (Heat rises), top and back mounted fans should generally exhaust. Generally front (or bottom - though I don't use bottom mounted fans) are used for intake.
Fan controllers/low RPM fans are useful if noise is a consideration. As are aftermarket CPU coolers, especially when overclocking.
Dust filters are your friend. Clean them regularly and consider purchasing aftermarket filters if you have any large openings/vents.
Outside of these areas there isn't a lot to go wrong unless overclocking. As many cases come with fans many beginners/inexperienced system builders really couldn't go wrong.
