ok thx I'll probably just go ahead and order that psu then after this last test fails which is just running the boot drive off a different sata port just to make sure it's not the mobo
Like I said, try the 1 dimm thing. It might still be bad ram.
I don't want to suggest buying a part that might not fix the problem is you haven't eliminated all other possibilities
Yeah I just finished testing the one ram thing and it crashed on both individual sticks so I'll just get that power supply
cool, I'd hate do mislead someone from gun jumping
very likely it's a bad mobo, bad PSU or both.
