Hey guys my card is dying(the on in the subject) and was wondering what u guys thought i should replace it with?
I was looking online and seeing that GTX 970 is around my price range.
Im not really into computers but i like to play games like BF3/4 and SWTOR.
So if i need to add more info about my PC let me know how to find it and i will happy do so :).
And of course thank you in advance.
The 970 is a great choice. Also look at the R9 290. It is pretty close to the 970 and much cheaper.
However, you may wanna wait (if you can) a few months as AMD/nVidia will both be dropping new GPUs.
I would love to wait but my card is already dying (Crashes/overheatings). so i dont think i can wait to long
Hmm well as long as your fans are working you may wanna take the heatsink off and try reapplying the thermal paste. Tht could help with the overheating issues.
I found 2 cards on new egg and i was wondering which u would recomend.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500362&cm_re=Zotac_Video_Card_ZT-90101-10P-_-14-500-362-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487077&cm_re=nvidia_geforce_gtx_970-_-14-487-077-_-Product
EVGA is larger and cooler.
If you can pay for it and have a case that can fit it, go for the EVGA. Otherwise the Zotac isn't bad either.
Have you tried replacing the tim on the cooler. Yes, it usually voids your warranty but on older cards it might be worth it?
