Hey guys. I need a replacement for an i5-6200u. I wanna get a gaming laptop, and I found a good laptop, but I don't want a dual core processor. Ill give you the link, and see if you can find a processor compatible with this laptop's socket and specs. Appreciate it if you could find a quad-core processor. Thanks!!
It's likely that the processor is soldered into the motherboard on that laptop, you're probably better off just selling it and buying a higher spec laptop.
If you have thunderbolt on it an external GPU will do fine with that CPU. I think Razer is selling an ultrabook with the same or similar CPU and with the Razer Core external GPU is a decent combo. And surely has better thermals than a gaming notebook.
