My iHome mouse has recently suffered some damage to the scroll wheel and left click button after 2 years of use, and it only cost me 8 dollars. Amazing for the price, it got the job done quite well. Extremely comfortable ergonomic design helps too. But it is no longer gaming worthyy.
I've been looking for a cheap replacement, preferably under 10 dollars. I found this mouse that seems to be a complete beast for the price: http://www.amazon.com/E-3lue-EMS109BK-Precision-Control-1600dpi/dp/B005CPGHAA/ref=cm_cr_pr_product_top
But I would like other suggestions that may be better for the price point. I realize the price point is extremely low, especially for a gaming mouse, but money is short lol. I really just need it to be about as good as my iHome mouse, and I know there are much better mice out there for the price.
Thanks, I really appreciate the help.
My go-to site for inexpensive electronics that work, especially odds n ends, would be monoprice. They do have a mouse that looks promising, but it's a little more than $10, plus shipping.
http://www.monoprice.com/Product?c_id=114&cp_id=11401&cs_id=1140101&p_id=9287&seq=1&format=2
With that said, I think the gem you found would probably be the best bang for the buck out there.
You should consider the price of mice now with inflation. You probably won't find a new one for around $10.
Before I splurged on a g9x this was my gaming mouse for over a year. it's insanely comfortable and works well. it's still my back up mouse. it's 15 bucks but i think it's worth every penny.
http://www.newegg.com/Product/Product.aspx?Item=26-146-009%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20
I am currently using a similar mouse, it was under 12€
http://www.newegg.com/Product/Product.aspx?Item=N82E16826146010R
Comfortable as hell, it's laser so it doesn't glow like a pixie and its reasonably priced.
Two thumb buttons are very useful for Push-To-Talk functions in games.
I'm Cheap so I use a Zalman 7 button. 2 of the buttons being the DPI and auto fire buttons.
Needs a good surface to work good. Cost like $13-$18.
http://www.amazon.com/Zalman-Optical-2500DPI-Multi-Button-ZM-M300/dp/B007QXLSOG/ref=sr_1_1?s=electronics&ie=UTF8&qid=1389842044&sr=1-1&keywords=zalman+mouse
