Replacement 7870
So my HIS iceq turbo 7870 died on me, luckily Ebuyer.com is giving me a refund. They have stopped selling the HIS 7870's so i cant buy another.
I have £180 to spend on a new GPU and I'm unsure of what to buy, XFX, Saphire? Im also open to buying Nvidia.
Will you please recommend me a good GPU and brand?
Also dont link me to Newegg, Im in England. Usually http://www.ebuyer.com/ is cheapest.
Thanks in advance.
So essentiall you have 238.48 US Dollars. Get yourself a GTX 760. Or you can wait to see what the next generation of Radeons bring.
http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-5.html
can you put any or your own money to the purchase? or/ how much are you willing to spend?
See if you can't find a 7950 around that price where you are. We have one here.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202026
I'm already putting £40 into this, i suppose i could pull together another 20 or so but i doubt it would make a big diffrence.
my xfx 7870 has a little coil whine i would upgrade here soon the 7970 7950  are going to get cheaper
I suppose i could reach for the 760, its right on the top end of my budget. But is it really worth it?
It doesnt seem that there is a huge performance diffrence between the 760 and 7870, and the 760 is about £50 more expensive.
Also i need a Gcard asap, i long to play Arma 3 in ultra again! I cant wait for the next gen to come out.
I was thinking of getting either,
http://bit.ly/1485FDH    or
http://bit.ly/1bktLmg
MSI Radeon HD 7950 3GB Video Card £185 FREE Bioshock Infinite + Crysis 3
http://www.scan.co.uk/products/3gb-msi-radeon-hd-7950-overclocked-28nm-5000mhz-gddr5-gpu-830mhz-1792-cores-dl-dvi-i-hdmi-2x-mini-dp
yeah pickup a Radeon 7950, that msi that cooperman posted is one of the cheapest. but still a good card. or a HiS 7950.
Wow that's an awesome deal!
Ty!
Yup like cheap , jump all over that.
When you order from scan untick there shiping 'insurance' saves you £5 and i dont know why thay offer it as if you get a broken item thay replace it anyway.
Fast service from them if you order now you will have it tommorow morning :)
Thank you very much for the help, I appreciate very much! *says in borat accent*
Thank you to everybody actually, i would be a toadl n00b with out TekSyndicate
