Repeating error filling my syslog
kwin_core: parsing edid failed
This is causing gigabytes of data to be written to my message log. Any simple way to suppress this message?
I know its caused by my using a DisplayPort to HDMI adapter, but the message is killing my logs.
Thanks.
systemd, syslogd, some other log server, or directly written to /var/log by the application?
If it’s systemd and logged to the journal as the kwin_x11 unit - so you have entries from running journalctl -u kwin_x11, then I don’t know a way to change journald to filter them before being logged but you can log a unit to RAM (man journald.conf, search “Storage=”) and restrict the max size.
To do so, create /etc/systemd/journald@kwin_x11.conf with the contents:
[Journal]
Storage=volatile
RuntimeMaxUse=1M
Then systemctl restart systemd-journald.
