I think only you guys have the resources to work on this so here it comes.
I was searching through several forums but couldn't find a solution.
How do the current GPUs stack up render wise I know there is CUDA on the Nvidia ones and OpenCL(?) for the AMD ones. But how does e.g. the 780 stack up against an 290x or 290 when it comes to rendering. Many people start getting into making videos so this might be quite an insteresting thing to cover.
I have a build I am about to order so I went with 2 asus gtx 780 instead of quadro since most of my editing is done with Adobe suite of products, and also Magix Movie Maker vPro5/and cosumer versions as well (which also supports multi GPU when editing and exporting. The Cuda cores and OpenCL are pretty much the same in some areas and mixed in other areas where cuda outperforms and some things and opencl on others. (note this is true for the PC Windows and Linux environments but opencl under a Mac is actually slower in comparison based on various reviews but would like to see a true head to head one day between both platforms. I went with Geforce 780 gtx(currently running 770 and 660 no issues) due to many past experiences with ATI/AMD driver issues causing crashes and stability problems (sorry amd, gave you way to many chances thru the years and spent a lot of wasted money too) Nvidia has been rock solid for me for at least the past 6 years. Once my systems are built (2 of them) I can provide a bench results later. Have my own dilemma between a CPU of i7 4930K 6 cores 3.4ghz or 2 dual Xeon 2630 v2 6 cores each 2.6ghz trying to figure out price vs performance ratio. Kinda leaning towards Xeon setup since I can update the processors to 10 or 12 cores later where as the 4930k will be maxed out the gate.
as far as comparisons out there for gaming between the 2 cards they are very close but NVidia is cheaper, less power consumption and runs cooler on most caparisons. But rendering data is really hard to tell and data that I have found is pretty slim and went both ways. From what I understand is that Cuda is a bit more stable than openCL and NVidia's drivers on cuda are a bit behind opencl... the new drivers coming may provide even more performance boost who knows. ITs a tough decision but I will get ya some benchmark comparison's on what I have as soon as I can.
