So I have successfully managed to connect into my home machine from work. As I work overnights, I don't get much things to do. To pass the time, I've tried playing a few games. However, any game that has a mouse look (FPS, thirdperson, mmos etc..) The mouse is super sensitive. I haven't found a fix yet to this. Thoughts?
It's probably the setting on your work PC, but that delay's gotta be killer man, if the setting is identical and your mouse dpi is identical than maybe it's just an issue with the remote desktop.
Should pick up a cheap laptop meng.
Not when you have 1Gig up and down. Latency isn't too bad. Hmm Would downloading and enabling remoteFX on the work PC fix it?
There's still a bit of a distance issue no? Otherwise not sure on that front.
Input latency is not too bad. I just played race the sun no problem.
