Remote access Android phone
Hello everyone!
Can anyone help me with the following - is there any way to make from a smartphone sort of a USB server? I have a pen drive which I would like to share across the network from my Android device.
There are samba apps for android but I’m fairly sure they all require root
Samba will not be able to forward data from a third-party carrier connected to the phone, since it gives access to the server where the data lies. And here as I understood it is necessary to transfer from USB …
but there is a program https://www.flexihub.com/ that allows you to transfer data through your remote location. Try it, maybe it will help you somehow.
