Region specific DVD's
I noticed that I only have 5 times to switch between the regions for my dvd's is there any software that makes it so that I don't have a limited number of region switches?
I believe it is set in the firmware of the drive so would be difficult to bypass, a better solution would be to rip and decrypt the video with software such as Handbrake or DVD Shrink.
Handbrake:
http://handbrake.fr/
DVD Shrink:
 http://www.dvdshrink.org/what_en.php
I'm pretty sure it a blend of firmware and OS standards.  I second ripping.  Here's an informative page on workarounds if you're interested.
http://howto.wired.com/wiki/Cheat_DVD_Regional_Encoding
You'd have to flash the DVD player.
I find the dvd codec horrid, and is really oudated. http://youtu.be/Uyxy9DCrq1U?t=6m17s
