I'm purchasing a reference r9 290 soon and will be water cooling it in the future. My question is which brand should I get as I've lost a few cards in the past and they haven't been covered by warranty so which brand will allow me to remove the stock heatsink without voiding warranty. Also I'm from Australia if that makes any difference
I think Evga and Asus are cool with removing the heatsink as long as you don't damage anything. The 290s do have a sticker on them that prevents you from removing the cooler without removing the sticker first. They can definitely tell if you removed the stock heatsink and can still reject your RMA. However, if you are planning on replacing the heatsink on an AMD card I would probably stick to Asus because they seem to be the most lenient out of all the AMD partners.
XFX allows you to use aftermarket cooling as long as you notify them before doing so.
EDIT: Nope nevermind.. I missed your last sentence about being in Aus. In that case I wouldn't have a clue what manufacturers are ok with modifying since warranties may be different between here in the U.S. and Australia. My apologies.
Thanks for this post. Extended warranties are offered for virtually any important buy. Customer electronics and home purchases are especially common opportunities. Extended warranties are often expensive. Basically, the plans are insurance policies on your products. Many individuals don't realize, though, that extended warranties can sometimes be added for no additional charge.
You can get away with removing the stock cooler so long as it doesn't interfere with the warranty stickers, or, remove warranty sticker in a very careful manner that you can stick it back looking untouched.
