Reducing clamping force with AKG K612 Pro?
I bought these headphoses about 6 months ago and they are the most comfortable pair I’ve ever owned. There is room for improvement, however. AKG K612 Pro’s are very light headphones and since I don’t headbang or walk around with them the clamp is unnecessarily strong.
Google Drive image
I read somewhere that you cannot strech the band the same way you can in some other headphones as it will break these. I circled the areas that bend when I put the headphones on my head. As you can see from the image they clamp more from the bottom than they do from the top and I don’t like that. I’m asking if some DIY expert knew a practical way of keeping the circled areas straighter to relieve clamp on my head.
