So I got a modular PSU finally along with some cable extensions and made my PC look even cleaner
Before:
[img]http://i1222.photobucket.com/albums/dd500/MrPete1985/20130301_165235_zpsf486ca95.jpg[/img]
After:
[img]http://i1222.photobucket.com/albums/dd500/MrPete1985/20130404_104218_zps2d743933.jpg?t=1365089093[/img]
I am using a Seasonic X750 Gold I used a single Molex cable from the power supply then I used some Bitfenix Alchemy cables for my extensions, now that I have all black cables my case looks so much better and I was able to route the cables from the Kraken around the back of the motherboard instead of over top of my RAM.
I also removed the hot swap PCB because the green board was messing up my color scheme.
Looks clean as hell man. What's your CPU + GPU, and is that an Intel SSD I see in the bay?
Samsung 830 SSD, for the CPU I have a FX8350, I'm still using a 6950 but I got one of the early models and flashed it with the 6970 BIOS, I'll probably upgrade my GPU when the next generation card come out.
NZXT Kraken looks amazing in that build. I wish I could afford one of the X60s, but for now I'll have to go cheaper and get a Seidon 240. But everything in your build does liik very clean. I'm just a little put off by the lack of flashy heatsinks stuck all over the place. I love the look of MSI boards with their copious use of pretty aluminum heatsinks, so it's just a little lacking for my taste, but it does still look very nice, and incedibly clean. Good job.
