Long story short I got a CM HAF 932 looks like shit inside with my current set of red LEDs makes the gray look some kinda wimpy pink so Im gonna slap some red in there to make the PC look better and not have some bitch pink in my case. Since its my first time painting. I may screw up because Im trying to do each piece quickly if I do end up screwing up, Im just gonna accept the fail and go all out black.
This case is good but requires some maintainance depending on your fans. Most flexible airflow configurations which is why I've personally chosen it. The more fans the more dust pretty simple. Takes 6 seconds to get each side cleaned up. Cable management is G. I still got a but load of cables but its only because they have been undone so often I didnt put the effort into organizing the hiding spots. get the tempest if you have an average amount of gear in your build. Lastly I bought mine for just under $190 CAD and comes with a four fan headstart. (3x 230mm and 1x 140)
vids wont happen but Ill do a friend's pc in the near future I recommended him to got with the TWELVE HUNDRED or my case I hope he picks mine for the sake of getting more experience with painting and if he does then I will surely have my cam by then. Upgrading to i7 is first on my list, 2nd is finding a new job, 3rd buy an HD cam, 4th buy a new skateboard for spring.
