Red CPU air cooler
I have a quite a limited budget. I do not want to water cool, I want to use an air cooler. I am building a pc with an ATX board and midi case and a FX6300.
The build is themed red and black and therefore I would like a red CPU cooler, but I am struggling to find one with a good reputation.
I was considering using a cooler master hyper 212 evo and replacing the fan with two Corsair Air Series AF120-LED in a push pull configuration. I don't know if this is a good idea?? Or perhaps it will just be easier to find a red cooler, however I have had little success.
Any help would be appreciated thank you.
The Termaltake frio Advanced is Black/Red but it is quite expensive.
if you go black/red it would be better to find one that is just black
Phanteks PH-TC12DX_RD
http://www.phanteks.com/PH-TC12DX.html
Not sure about the cooling ability but Raijin tek do red/white and eem pretty nice. And fairly easy on the wallet.http://www.overclockers.co.uk/productlist.php?groupid=701&catid=2330&subid=2666
Prolimatech Megahalems Red http://www.prolimatech.com/en/products/detail.asp?id=2067&subid=2069#showtab
Might be hard to find and too big for a midi case though.
