Red/Black CPU Heatsink and Fan
I'm building my first rig and I'm looking for a good red and black CPU heatsink and Fan.
Here is my build http://pcpartpicker.com/user/GamingFTW/saved/3lfV
I have a hyper on there now. But I would like a red and black cooler.
I also could get a Noctua D14 or D14s. However, I don't think it would perform at 100%.
Thermaltake NiC C5
Has some pretty favourable reviews.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103189 Little pricey but if your going for looks. This should match up well with your projected build.
http://www.youtube.com/watch?v=w8A4CoKiAsc
Yes I shall be getting this!
Ha Ha, I almost grabbed one myself but my mb is a saber ao i went noctua. Heres some ram that might be cool
https://www.youtube.com/watch?v=U8SKdCJ4-pQ
Bling Bling ! LOL
Actually on second thought I think temps would be better than looks. What I plan on doing is just coloring a noctua. Would that be feasible?
I can't believe no one has thrown Phanteks in here yet.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709021 120mm traditional RED heatsink with RED and WHITE fans
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709016 dual 140mm updraft/downdraft RED heatsink with RED and WHITE fans
http://www.amazon.com/dp/B005ORDOBQ/?tag=pcpapi-20&tag=amaflink-20 dual 140mm double tower RED heatsink with RED and WHITE fans
You could put some noctuas on them if you'd want but it wouldnt be necessary since Phanteks are really good fans also.
If the Red and black matters that much then pick up some BitFenix Spectre Pros that are the translucent black with red LED here (amazon link has all the sizes you'd want)
Not really sure on how feasible it is. I lean on performance more than anything. I mostly run mutt mixes since i am always swapping gear. Personally, i prefer cool and quiet over looks.
What I could do is get a black heatsink http://www.newegg.com/Product/Product.aspx?Item=N82E16835709011
and then put a few red fans on it http://www.newegg.com/Product/Product.aspx?Item=N82E16835709028
Then I could take out the fans and spray the outer ring either black or red. Thats the only problem I don't like about the fans on the Phanteks is that they are white.
Cooler master v8
"I also could get a Noctua D14 or D14s. However, I don't think it would perform at 100%."
I am sorry but what do you mean by this. I would assume a D14 would be up with the bet you could get cooling wise.
I ment to say I could get a noctua and color the fans red.
